Arduino Board setting?
Posted: Sat Mar 23, 2013 10:38 pm
by cassetti
Question? I know what port to use, but what board do i select? Current it's set to Azteeg X1. I'm pretty sure that's not what I want.
I'm running Arduino 1.0.1
Re: Arduino Board setting?
Posted: Sat Mar 23, 2013 10:40 pm
by cambo3d
arduino mega
but you should use arduino 22 or 23 if your installing marlin firmware.
you can use arduino 1.03 with repetier firmware.
Posted: Sat Mar 23, 2013 10:43 pm
by cassetti
Wait, I just saw something about installing using repetier-host, is that true?
i'm trying to use Polygonhell's version of the firmware.....
Posted: Sat Mar 23, 2013 10:44 pm
by cambo3d
repetier host and repetier firmware are two different things.
use arduino 1.03 if your installing poly's repetier firmware then because its known to work.
Posted: Sat Mar 23, 2013 10:48 pm
by cassetti
cambo3d wrote:repetier host and repetier firmware are two different things.
use arduino 1.03 if your installing poly's repetier firmware then.
Gotcha, and I want to select the board "Mega 2560" to be specific, correct?
by cambo3d
yes, rambo is based on arduino mega 2560
