Question? I know what port to use, but what board do i select? Current it's set to Azteeg X1. I'm pretty sure that's not what I want.
I'm running Arduino 1.0.1
Arduino Board setting?
Re: Arduino Board setting?
arduino mega
but you should use arduino 22 or 23 if your installing marlin firmware.
you can use arduino 1.03 with repetier firmware.
Wait, I just saw something about installing using repetier-host, is that true?
i'm trying to use Polygonhell's version of the firmware.....
repetier host and repetier firmware are two different things.
use arduino 1.03 if your installing poly's repetier firmware then because its known to work.
Gotcha, and I want to select the board "Mega 2560" to be specific, correct?cambo3d wrote:repetier host and repetier firmware are two different things.
use arduino 1.03 if your installing poly's repetier firmware then.
yes, rambo is based on arduino mega 2560
