KISSlicer 1.1.0 Release Candidate
Posted: Mon Mar 11, 2013 5:19 pm
Release candidate for 1.1.0 was made today. Get that last minute testing and bug reports in!
Changed since last beta:
Better packer
Fixed "count = 0" bug (would not slice, then not save, if one objects count was 0)
Better translation
Added axes transformations (right-click on model tab)
Updated compiler for Windows builds...not sure if this will be noticeable
Disallow slashes in profile names, disallow duplicate profile names
Z slider can now show the layer's Z value in model space, or in G-code values
Changed path color scheme...hopefully clearer (and removed "pause" [8^)
Can change 3D background color
Added an option to translate only the tooltips, leaving the interface the same
Added a distinct "Use Wipe" option in style (so it's not controlled by "use Destring")
Fixed "Extruder selection" bug.
Generic fan commands (mostly for makerbot)
Logs "Support" profile settings to the G-code file now
Fixed a bug with segmented adaptive support and infill (right before the solid layers)
Throws a warning on empty paths after slice
Added <E> G-code token (for use with makerbot again)
Some small UI changes
