Changed since last beta:
Better packer
Fixed "count = 0" bug (would not slice, then not save, if one objects count was 0)
Better translation
Added axes transformations (right-click on model tab)
Updated compiler for Windows builds...not sure if this will be noticeable
Disallow slashes in profile names, disallow duplicate profile names
Z slider can now show the layer's Z value in model space, or in G-code values
Changed path color scheme...hopefully clearer (and removed "pause" [8^)
Can change 3D background color
Added an option to translate only the tooltips, leaving the interface the same
Added a distinct "Use Wipe" option in style (so it's not controlled by "use Destring")
Fixed "Extruder selection" bug.
Generic fan commands (mostly for makerbot)
Logs "Support" profile settings to the G-code file now
Fixed a bug with segmented adaptive support and infill (right before the solid layers)
Throws a warning on empty paths after slice
Added <E> G-code token (for use with makerbot again)
Some small UI changes
KISSlicer 1.1.0 Release Candidate
Release candidate for 1.1.0 was made today. Get that last minute testing and bug reports in!
