Re: kbob and Impulse, the Rostock MAX
Posted: Wed Oct 30, 2013 11:46 am
Here ya go.
Have a look around and join today!
https://images.seemecnc.com/
woohoo! thanks!Eaglezsoar wrote:Here ya go.
So I tried it. It was easy to see that (a) the X carriage moves easier than Y or Z, (b) the motor pulley turns when the carriage moves, (c) the movement has the zip/step feeling of a stepper motor rotating.Turn the printer on and Home it, that should lock the steppers. See if you can grab the carriage and slide it down the tower. If it's loose it should allow the pulley to slip while the shaft is locked by torque.
You're probably right. The cable is too short already, so maybe it's time to solder on an extension and make new connectors.geneb wrote:If it was MY printer, I'd cut replace the crimp sockets - you may have a set that's simply out of spec. I say that because I've got three v1s (all are 2013 vintage) that I've nearly beaten to death and of all the issues I've had, a) all are my own damn fault and b) never a motor connection.
