Opinions on the Pocket NC 5-axis CNC mill?
Posted: Wed Mar 02, 2016 10:11 pm
[youtube]http://www.youtube.com/watch?v=UQutUdOg3gI[/youtube]
It costs $4,000 and is currently in the post-Kickstarter phase. (They pulled in $355,000 during their campaign.) It can take straight G-code, but was developed with and uses Autodesk Fusion360 for the toolchain - you get a year's subscription to that with your purchase. A BeagleBone Black + steppers are used for motion control - not sure whether they use encoders, but I'm guessing "probably not." The work envelope is 4.5 x 4.8 x 3.3 inches. The spindle runs at up to 10,000 RPM, and has an advertised runout of 0.000078".
I'm looking for feedback from people who have experience working with CNC mills, in terms of build quality, choice of drivetrain components, backlash, accuracy, and how well it's likely to stand up to machining forces. (The deflection numbers look "okay" to me.)
I have a few projects I'd like to use this on, but mostly I'd be renting time on the machine to others in order to defray the cost.
Specs:
X Axis
Max Speed: 40 ipm (inches per minute)
Resolution: 0.000125in
Backlash: 0.0005 in at tool base
Deflection at 5 pound load : 0.001 in at tool base
Max Travel: 4.5 in
Homing Repeatability: +/-0.0005 in
Repeatability: +/-0.002 in at 0% load
Y Axis
Resolution: 0.000125 in
Backlash : 0.0005 in at tool base
Deflection at 8 pound load : 0.001 in at tool base
Max Travel: 4.8 in
Z Axis
Backlash at 18 pound load : 0.0005 in
Deflection at 18 pound load : 0.001 in
Max Travel: 3.3 in
A Axis
Max Speed: 20 degrees/second
Resolution: 0.025 degrees
Backlash: 0.05 degrees
Deflection at 2 pound load : 0.001 in at table center
Max Travel: 100 degrees (90 degrees +/- 5 degrees)
Homing Repeatability: +/-0.05 degrees
Repeatability: +/-0.05 degrees at 0% load
B Axis
Max Speed: 40 degrees/second
Max Travel: continuous rotation
Spindle
Spindle Speed: 65-10,000 rpm
Power Output: 104 Watts
Spindle Motor: BLDC 3 Phase with Hall Feedback
Spindle Runout: 0.002in or better
Tool Change: Lever Type (no wrenches needed)
Tooling: 1/8in shank (collet for 2mm, 3mm, or 4mm can be purchased)
Machine Control
BeagleBone Black running Machinekit/
Features
Spindle Override
Feed Override
Stop, Start, Pause
Jog while pause
5 axis simultaneous movement
Ethernet, USB, mini USB, and HDMI ports
Accepts Standard Gcode
Power Source: 90-264 VAC, 127-370 VDC, 47-63Hz
Components
7 NEMA 17 Motors
3 linear lead screws with preloaded nuts
4 rotary 8/1 belt drives
Linear Bearings, 9 & 42mm, 10% preload
Angular contact rotary bearings
6061 Aluminum Frame, +/-0.002in squareness
Machine Dimensions:
Fully extended: 17.5 in wide(444.5 mm) x 12.5 in (317.5 mm) tall x 12.5 in (279.4 mm) deep
Fully compressed: 13 in wide (330.2 mm) x 9.5 in (214.3 mm) tall x 9 in (228.6 mm) deep
Software
Autodesk Fusion360, post processor included
Specs:
X Axis
Max Travel: 4.5 in
Y Axis
Max Travel: 4.8 in
Z Axis
Max Travel: 3.3 in
A Axis
B Axis
Spindle
Machine Control
Features
Spindle Override
Feed Override
Stop, Start, Pause
Jog while pause
Components
7 NEMA 17 Motors
Machine Dimensions:
Software
