PEEK Fan not working
Posted: Sun Feb 28, 2016 7:26 am
by enesoz
I have wired up and installed the fan to the shroud but the fan is not spinning even after I have turned the fan on, on the control settings in MC.
In the manual it states "If it's not blowing air, you've likely connected the wires backwards. :) Correct it and try again."
Does this mean I have got the layer fan wires and the peek wires the wrong way around?
Re: PEEK Fan not working
Posted: Sun Feb 28, 2016 9:07 am
by IMBoring25
I think it means you switched the hot and the ground. To make sure, though, it won't turn until you turn the hot end on.
Posted: Sun Feb 28, 2016 11:20 am
The PEEK fan isn't under manual control - it will only start after the hot end hits 60C.
