New build of a Rostock Max kit
Posted: Fri Dec 21, 2012 3:42 pm
Hey, I'm starting the build of a Rostock Max kit and have a couple of questions / comments
My kit is wood and has the LCD screen and the ONYX build plate
I also noticed (like some other folks) that the laser didn't completely cut through the board for some of the parts. My experiance was very similar to the others as far as the part of the board and part numbers affected. I just thought you guys would want to know.
I have also noticed that my lower plate doesn't have the 4 small slots behind the electronics board. My parts are labled R7 (revision?) so, I'm wondering if I need to vent that area behind the electronics panel or you decided to take that feature out and the video and eDrawing is just older/newer. Just curious unless you think I need to drill some holes to vent that area. I guess I'll find out by how hot things get.
Another note is that my parts stink (as in smell)... My wife has sent me out the garage to leave the wood parts... Not sure if it's the singed edges from the laser cutting or what, but, there is a strong odor coming off of the wood parts... I assume it will get better with time? I didn't notice it at the shop the other day...
Are there pictures / instructions about how you route the wire for the ONYX build plate? What about if I should mount it before the motors and extrusions? It seems like I'd want to put that on as one of the last things... I think the square one you install first since the holes get covered by the ATX power supply. Just curious if the larger round one doesn't have that problem, so I can leave it until later...
Tony
Tony
