Cut ribbon cable?
Posted: Thu Dec 31, 2015 8:29 pm
Hello all.
One of the two ribbon cables I received in my kit has wire #10 cut on it near the connector at one end. I say "cut" but it looks a bit sloppy like it might have been crushed / damaged. I've already ordered some new ribbon cable connectors from amazon and plan to remove the damaged portion of the cable and attach a new connector, but before I did, I just wanted to make sure this isn't a "feature" , i.e., that some new version of the LCD that is now shipping doesn't actually REQUIRE this cable to have this wire cut. There is nothing about that in the manual, but I've found several errors in the latest version of the manual as I've been building, so thought I would double check.
Chris
Chris
