PEEK fan failure
Posted: Tue Dec 29, 2015 10:42 am
by Aureus
Hello all,
I just installed my PEEK fan and I am certain that I got the right wire pair, but when the hot end temp starts rising, the PEEK fan does nothing!
I don't have any clue about what I did, if anyone can help that would be awesome!!
Re: PEEK fan failure
Posted: Tue Dec 29, 2015 10:58 am
by DeltaCon
Do you have current on the wires? Switched + and - ? My fan wouldn't even turn backwards when I got the plus and minus switched.
Posted: Tue Dec 29, 2015 11:51 am
by Aureus
Hi DeltaCon,
I have checked the wires and they are indeed correct, and the HEAT 1 is getting 12 v to it. I still have no idea what is wrong.
Thanks,
Posted: Tue Dec 29, 2015 12:36 pm
by Xenocrates
Give the fan a manual couple of spins. If it's not smooth, either the bearing is toast, or something is interfering. Likely a string from the holder, or the holder being a bit too snug. Also, try swapping the polarity of the fan and give it another shot. If that doesn't help, then I suggest you remove it from your printer, and use a yankee'd computer PSU to test it (paper-clip shorting the green and a ground lead), and then connect a yellow and a black lead to the fan (12V+ and ground)
Posted: Tue Dec 29, 2015 12:48 pm
by Aureus
Alright, I will try that Xenocrates
Posted: Tue Dec 29, 2015 12:56 pm
by Aureus
I took the fan out of the fan shroud and it started running, so I will sand the fan shroud down and hopefully it will work.
Posted: Tue Dec 29, 2015 1:20 pm
by Aureus
Sanded the fan shroud down and it works! Thank you all for helping me!
Thanks,
