weird warping
Posted: Sat Dec 26, 2015 10:55 am
by DarthBeavis
Can't figure out what is causing this warping. The piece on the right is warped the one on the left is how it should look. Any ideas?
[img]
http://imagizer.imageshack.us/v2/1024x7 ... 8Rio8e.jpg[/img]
Using custom Rostock and Simplify3d
Re: weird warping
Posted: Sat Dec 26, 2015 11:33 am
Image didn't post correctly.
Re: weird warping
Posted: Sat Dec 26, 2015 12:31 pm
by Xenocrates
http://imagizer.imageshack.us/v2/1024x7 ... 8Rio8e.jpg Is the image. I think it's an odd bit of layer shifting, but it's hard to tell. Have you changed much between the two parts?
Re: weird warping
Posted: Sat Dec 26, 2015 2:14 pm
Xenocrates, I can't get your image to open either.
Re: weird warping
Posted: Sat Dec 26, 2015 2:58 pm
by DarthBeavis
Re: weird warping
Posted: Sat Dec 26, 2015 5:38 pm
by Tincho85
I can't see the image either.
Re: weird warping
Posted: Sat Dec 26, 2015 5:49 pm
by Xenocrates
That's really interesting. Are you using the same G code for them both? Would it be possible to use the same G code (is the nozzle size and so on close enough for that to work)? Do you see this on any other parts?
It looks like it might be resonance in the drive system or a slicing bug almost, since it's so regular. Have you checked the mechanics and if your hotend holder is loose?
Re: weird warping
Posted: Mon Dec 28, 2015 3:57 am
by magicmushroom666
Did the code come from Slic3r? There's a bug in the latest version that causes thin walls to bulge like that...
https://github.com/alexrj/Slic3r/issues/2960
