Rostock Max V2 with a few minor mods
Posted: Mon Dec 21, 2015 2:28 am
Just wanted to share a few of the mods I made to my V2 as I was building it up and making a few upgrades shortly after.
At first it was a fairly stock build with just a splash of blue to get an R2-D2 vibe going on.
[img]https://farm6.staticflickr.com/5739/23882558035_cb48007532_k.jpg[/img]
After a few prints for the PEEK and layer fan shrouds, I thought it seemed a bit noisier than it needed to be. I ordered and installed the Astrosyn stepper motor dampers.
I also felt the MDF panels were contributing to the acoustic enhancement properties of the motor. Using a basic butyl rubber with foil backing option I found on Amazon, I was able to make sure I could print through the night in the basement without keeping the family up.
[img]https://farm6.staticflickr.com/5734/23774290492_bf4eea7dde_k.jpg[/img]
[img]https://farm6.staticflickr.com/5819/23774291762_58b9db216f_k.jpg[/img]
[img]https://farm1.staticflickr.com/635/23255813293_b574db836c_k.jpg[/img]
I also wanted to be able to remove the USB cable easily so I found a nifty panel plug online and installed that.
[img]https://farm1.staticflickr.com/635/23856517936_42f1a6a05a_k.jpg[/img]
[img]https://farm1.staticflickr.com/779/23882617265_a04c67f432_k.jpg[/img]
Then it was time to get down to the real reason of getting a 3D printer (besides printing replacement wheels for toys that I stepped on!!!) creating and making parts to solve or tweak design issues!!
I wasn't incredibly comfortable with the method for tensioning the belts. While I liked several of the other solutions I found out on the board, I really felt there had to be a simple yet elegant way to do it. So I came up with a couple of small cams that when used with a longer screw would provide a way to easily set tension. Other than needing a longer screw (Lowes carries 6/32 by 3" machine screws in stock by me), no other modifications are required.
[img]https://farm6.staticflickr.com/5742/23774283692_c4e2f9d4c2_k.jpg[/img]
[img]https://farm6.staticflickr.com/5726/23856514886_0467be2312_k.jpg[/img]
I even made a little tool that can slide over the two separate cams to enable even tensioning. The left cam includes a capture for the locknut so setting and locking tension is a two handed operation.
[img]https://farm6.staticflickr.com/5790/23856513626_6a27fec3dd_k.jpg[/img]
The tool and the cams are designed to be able to move the screw holding the pulley the entire length of the adjustment slot within 90 degrees of rotation and without having to re-index the tool. I printed all of this out of ABS and the cams print quite nicely, while the tool usually takes a slight bit of cleanup when I print it. I really need to get an enclosure set up as I am printing in my cool basement.
So I hope folks get a kick out of my little tweaks and upgrades and let me know what you think. Here is the Thingiverse posting for the tensioner cams and tool.
DodgeDerek
DodgeDerek
