This is what I call resolution
Posted: Wed Nov 18, 2015 7:35 pm
by teoman
Re: This is what I call resolution
Posted: Thu Nov 19, 2015 7:29 am
That was unbelievable Teoman, imagine what tools would be used to carve a speck of dust or print at that size.
Bet it wasn't done on a Makerbutt.
Posted: Thu Nov 19, 2015 10:13 am
by Xenocrates
From what I read, it uses a long wavelength laser, and a microscope, to cause double photon absorption, in order to reduce the cure area to a tiny footprint, even when compared to a UV laser. Impressive stuff, that is.
Posted: Thu Nov 19, 2015 10:33 am
Xenocrates wrote:From what I read, it uses a long wavelength laser, and a microscope, to cause double photon absorption, in order to reduce the cure area to a tiny footprint, even when compared to a UV laser. Impressive stuff, that is.
I would love to see the equipment that they use, it would have to something to see.
Posted: Thu Nov 19, 2015 2:43 pm
by teoman
A decade ago I had the equipment and knowledge to do this but I did not get the idea.
Posted: Fri Nov 20, 2015 12:06 am
by 626Pilot
teoman wrote:A decade ago I had the equipment and knowledge to do this but I did not get the idea.
Well, now it's today. What are you going to do about it? I'll write the firmware :)
Posted: Fri Nov 20, 2015 11:56 am
Posted: Fri Nov 20, 2015 2:04 pm
by teoman
I have kind of shifted from microsystems where i used piezo stages that had a couple of nanometers resolution to industrial robotics and now to mobile application (sensor heavy) development with the occasional mechatronic project on the side.
It was one of those moments where i said "dang, i wish i had thought of that!"
