Software upload problem to Rambo
Posted: Sun Oct 04, 2015 4:57 pm
by rehabmax
Has anyone else encountered a problem when trying to get the software onto the Rostock Max v2.
I have finally completed the assembly and put all the wiring harnesses onto the Rambo board.
I have the Arduino application n my computer and USB cable is in place.
I ran the EEPROM-clear program. When I upload the Repetier.ino the program appears to goe through onto the board, the yellow light glows, blinking rapidly during the upload.
Then nothing. My LED board is lit, but with 2 blank lines. No information. The yellow light blinks slowly.
The power is normal, Green light is on. The fan I soldered to the board is running. The LED display, is illumnated just no information.
I have repeated these steps multiple times. i have rechecked every single connection. All terminals are lined up as best I can see. The ribbon connectors are seated properly. i believe I followed the manual properly in the assembly.
I cannot figure out what i did wrong.
Any suggestions ?
Update 10-13-15.
SeeMe CNC was kind enough to send me new LCD kit without charge. Everything is working well now. All the calibrations have been made. I have been busy making the fan shrouds and hope to make some neat Halloween pieces. I am blown away at the accuracy of the printer.
Many thanks to JJ and SeeMeCNC.
I love the Rostock Max V2. So cool. The building process was a tremendous learning experience. I am so glad I bought the kit and not an off the shelf fully assembled one from another company. For the price, nothing that i have seen comes anywhere close to this.
Re: Software upload problem to Rambo
Posted: Mon Oct 05, 2015 12:17 pm
I suspect you've got the cabling to the LCD wrong. 99% of the time, that's why the LCD doesn't work.
Posted: Mon Oct 05, 2015 10:42 pm
by rehabmax
That seems to be the general consensus that my cables are wrong. I took the LCD interface board off the Rambo and double checked that I believe I aligned the pins properly. Cables A and B appear to be oriented correctly as well. I removed them and replugged them on both the PCB and the LCD. This did not seem to make any difference. Customer service is trying to help me out. I probably did something wrong somewhere.
Posted: Tue Oct 06, 2015 9:28 am
FYI, the yellow LED activity tells me the board is working - that's Repetier Firmware sending thermistor values back to the host.
While the connector on the LCD panel itself is keyed, the PCB end is not. Make sure you've got your pin 1 orientation correct. Having one or both upside down will result in the dual white lines.
Posted: Tue Oct 06, 2015 10:07 am
by Tincho85
What version of the Arduino did you use?
Try with Arduino IDE 1.0.5 (http://arduino.googlecode.com/files/ard ... indows.zip
I remember having issues with the latest version. Maybe it helps you too.
Oh and make sure to select the Board and the COM port
Good luck.
Posted: Tue Oct 06, 2015 4:36 pm
The issue he has doesn't involve the compiler at all.
Posted: Tue Oct 06, 2015 7:16 pm
by teoman
Can you connect and send commands via computer?
Posted: Tue Oct 06, 2015 9:38 pm
by rehabmax
I downloaded Matter Control and it can connect to the printer.
I am fairly convinced now that the LCD board is defective.
I have rechecked every connection multiple times. This is going on for 3 nights now.
Without a functional LCD the machine is a giant paperweight.
I can upload the Repitier.ino files to the board (the upload goes through in the Arduino window)
I do not think there is any problem with the Rambo board itself
Posted: Tue Oct 06, 2015 10:19 pm
by Earthbound
Please post clear pictures of each LCD cable connection.
