Need advice on my support and raft settings
Posted: Sat Aug 01, 2015 5:15 pm
I'm finally starting to get some reasonable prints, after chasing around loose delta arms ( which seems cnc kindly replaced) and struggling to get the bed up to temperature (which the light bulb on the 5v rail trick fixed)
My abs prints are now pretty strong between layers- but things seem to turn ugly when I need support.
I'm currently just using the support settings in mattercontrol, but wonder if I would be better using mesh maker.
Basically the support gets ugly, and ends up dragging the layers around the print, I think?
Settings are:
Support type : LINES
Amount: STANDARD
Pattern spacing:3mm
Infill angle :45
Interface layers: 2
X any Y distance 0.7mm
Z gap 1mm
The other challenge I'm having is the raft sticks too well- I can't get the print off it!
Any suggestions, or other comments based on these images is greatly appreciated.
Cheers
Jason
Settings are:
Amount: STANDARD
Pattern spacing:3mm
Infill angle :45
Interface layers: 2
Z gap 1mm
Cheers
Jason
