firmware for Rambo 1,1b/Rostock max.
Posted: Fri Jul 10, 2015 3:53 am
by Roof
Hello.
i have run into a problem. my fan_0 don not work. when i use the command M42 P6 S255 it turms on fan_1 and repetier can not use fan_1 as "intelligent" cooling for the print.
here is my Question: dos anny of you out there have a firmware that is redy to be uploaded to rambo? cause i am not that good at tweaking codes. and the one that can be downloaded from the internet as described in the "3d Manual" needs tweaking before it is redy to be uploaded to rambo.
I have a Rostock max. (version 1)
Rambo 1,1b
(and i am only using 1 extruder)
if more info is needed i will provide it as fast as possible.
Thanks.
