Hot camera - low cost - homemade.
Posted: Tue Sep 11, 2012 8:14 am
Hello,
I made a prototype camera hot low cost. This camera operates in open loop with temperature from 60 to 90 ⁰ C. No need for plate temperature control.
In the first minutes she reaches 60 ⁰ C.
Hours after it reaches approximately 90 ⁰ C.
terminals connected to 12V and current of 7A (open loop).
The prototype consists of a plate phenolite (Cu)20mmx20mm, welding, and 10m of 0.5mm Cu wire.
The design for the Cu plate is this:
[img]http://4.bp.blogspot.com/-dccJClmylA0/U ... quente.bmp[/img]
After erode the plate, you need to coat it with solder and fix the wire on Cu tracks.
I've only got a prototype of 60 ⁰ C to 90 ⁰ C. In my tests so far these characteristics remained unchanged.
The cost was R$ 12.00 = $ 6.00 U.S.
Photos finals.
[img]http://4.bp.blogspot.com/-nLQvl6hIuIc/U ... C01173.JPG[/img]
[img]http://1.bp.blogspot.com/-aYuCmYwCqCg/U ... C01205.JPG[/img]
Photos finals.
