Any tips for removing scuffs from translucent PLA?
Posted: Fri Jun 05, 2015 6:27 pm
Hey guys, so I'm starting to work more with PLAs, and it turns out the the PrototypeSupply/ToybuilderLabs/Inland blue PLA is translucent, which is kinda cool.
But when sanding, the surface turns opaque and totally loses it's sheen. Is this normal for PLA? or just for the translucent stuff?
I've tried polishing with oil, auto wax, and applying an acrylic sealer, and while the sealer did lessen the effect, it's still obvious and the sand marks are still opaque compared to the rest of the mode.
The tip was coated in an acrylic top coat, the rest was just sanded and buffed for a bit.
(I know that this is a very sloppy print. It was printed fast, and I sanded and filed the entire model for practice.)
Is there something that can be done eliminate the scuffs from sanding and filing? Is it something that happens with all PLA?
[img]https://lh3.googleusercontent.com/fTRbA ... 26-h893-no[/img]
