Axes Home Issue
Posted: Tue May 12, 2015 6:35 pm
Hi all,
I've reached the stage where it's time to start setting up the software. I've got the Arduino functioning and the MatterControl software can communicate with it properly. On page 229-230, it says to click the "ALL" button to send all the axes home. I see all my axes move in the proper direction (I changed the Configuration.h file). The X axis moves to the end-stop switch and stops moving. The Y axis is violently smacking against the top to the point where I can see the belt and entire platform shake. The Z axis moves up but does not hit the end-stop. I checked using the M119 command, and I'm getting proper readings there; when pressed, it says "H" and when not pressed it says "L." Any idea what is happening here? That "G0 Z200 F3500" code doesn't stop the axes from smacking into the end-stop either.
Thanks,
Derek
Thanks,
Derek
