EZStruder spring?
Posted: Mon Mar 23, 2015 4:05 pm
by Glacian22
Hey, does anyone know where to get a replacement spring for an ezstruder?
Re: EZStruder spring?
Posted: Mon Mar 23, 2015 6:42 pm
by DanHall
Probably not much help but some local hardware stores in my area have drawers full of springs. If the one you have isn't damaged too badly just take it with you and look for a replacement.
Posted: Mon Mar 23, 2015 9:12 pm
by Glacian22
I've looked around for one, but haven't been able to find one that's the same size and tension
Posted: Mon Mar 23, 2015 9:16 pm
by Nylocke
http://m.homedepot.com/p/Spring-Assortm ... 202045461/
Get a bunch for pretty cheap. There is one in there that fits relatively the same as the regular with about the same tension. I've used them a lot. A crap load of springs come in handy.
Posted: Mon Mar 23, 2015 9:58 pm
by Glacian22
Mike, you rock. You're a regular Rockasaurus Rex. And actually the extruder that this will be going into is a version of your ezflex, modified to work with a planetary geared motor. ^_^
Posted: Mon Mar 23, 2015 10:05 pm
by Nylocke
Glad I could help
You going to share that?
Posted: Mon Mar 23, 2015 10:10 pm
by Glacian22
Share? Shaaaaa-aaaare...what is this word?
I wanted to give it a solid burn in test before I posted it, so last night I ran a 12 hour print on it, successfully! .3mm layer height, .4 nozzle, 80mm/s with PLA...it moves plastic like a beast. I'll see about making a youmagine account so I can reference your original design.
Posted: Tue Mar 24, 2015 3:52 am
by Renha
Glacian22 wrote:Mike, you rock. You're a regular Rockasaurus Rex. And actually the extruder that this will be going into is a version of your ezflex, modified to work with a planetary geared motor. ^_^
wow! We'll wait
