PLA bed adhesion
Posted: Fri Mar 06, 2015 12:29 pm
by jponitz
I am having a problem with PLA curling off the bed of my new Orion. It's strange because I have another Orion that hasn't had this problem, and I didn't think this was typically an issue with PLA.
Bed temps have ranged from 40-70
Using glue stick for adhesion
Nozzle temp 200-210
First layers .35mm thick, 30 mm/sec
Have tried with the cooling fan on, and off
Any ideas where I'm going wrong?
Re: PLA bed adhesion
Posted: Fri Mar 06, 2015 12:36 pm
by KAS
Do you know it's PLA for sure? lighter trick?
[youtube]http://www.youtube.com/watch?v=cvg3u89EJwA[/youtube]
Posted: Fri Mar 06, 2015 12:38 pm
Have you read my guide?
Fingerprints, potato chip grease? Have you printed with this roll of PLA on the other Orion?
My guess is your Z height is not correct. Increase your Z height in increments of .05mm and test print my single layer object until you get one that sticks. NO cooling fan on first layer!!!
Posted: Fri Mar 06, 2015 1:42 pm
by jponitz
Thanks KAS and mhackney, I will test out your suggestions and let you know what I find. I have a sneaking suspicion it's the Z height.
