Layer Fan Shroud for V2 STL issue
mvansomeren
Post by mvansomeren »
When I go to the link provided in the manual and download the Layer Fan Shroud for V2, it's an invalid STL file. I see comments on that site where others are experiencing the same issue. I've found an older version but it doesn't have enough clearance for the V2 version of Printer.
Does anyone have the correct Layer Fan Shroud STL file that you can post?
Thanks in advance!
Earthbound
Re: Layer Fan Shroud for V2 STL issue
Post by Earthbound »
Here is the one I like best.
NEW3-Guanu-Blower-Fan-Shroud.STL
(87.39 KiB) Downloaded 631 times
mvansomeren
Earthbound wrote:Here is the one I like best.
Thank you so much! I'm not sure why it hasn't been corrected on the website since it has apparently been a problem for a few months now.
