Calibration Help
Posted: Sun Feb 22, 2015 9:20 am
Without going into a very long story, after about a year of messing with my printer I have finally been able to print something. I calibrated per the instructions and ran some additional calibration tips I found on the net specific to the Rostock. I ran the small cube test and had pretty good results for a first print, but it looks like I need to fine tuning. I have included the cube print as well as a partial calibration print. If you look at the cube you can see that on some corners it seems to overshoot the corner and bulge out instead of making a clean corner. In some cases the bulge is only on one side of the turn and not the other. In other cases it is on both sides and in one case the corner looks perfect. I was pretty happy with the print as I had no strings or very few imperfections on the walls. I assume this at least means my retraction settings are pretty much perfect.
After the cube print I found a calibration file specifically for delta printers and gave that a go. I stopped the print after a few rounds. I highlighted what looks like thin areas where I believe the head is too high. At least I think it's too high. So my question is where to begin fine tuning? Since I am new to 3D printing can I get some somewhat detailed help (ie. explain it to me like a noob).
Some info
.91 firmware
Printing ABS
Head 230 (E3D not stock)
Bed 95
Default Repetier first height and subsequent height
*edit
Also the print seems to just quit LCD says KILLED. The timer reached zero and it just dead stops. It's seems to be right at the end of the print. Maybe 2 layers left. When it does I lose all control of the printer. I can't send any commands at all they just queue up. I have to disconnect the printer from the laptop and reconnect. This seems to be a wide spread issue after some searching, but I don't see any solution.
Some info
.91 firmware
Printing ABS
Bed 95
*edit
