Calibration and Horizontal Radius
Posted: Sat Jan 24, 2015 5:59 pm
Ok well "Yay!" got the printer built and everything is working and no smoke.
I'm having a problem though have have tried for over 2 hours to fix and I cannot seem to figure it out.
I have Set the Z height on the lcd. I have adjusted the end stops and calibrated the x, y and z. but the center just will not calibrate right with the horizontal Radius.
Nothing I do seems to change it. I can jump it huge amounts and it doens't change anything. I don't know what i'm doing wrong.
I save to eeprom each time but nothing changes. I started at 130 and it comes to tight to glass and I have reduced it all the way to ever 80 and it doesn't change anything. if I adjust it .1 up 3-5 clicks had it prefect but I cannot get that Horizontal radius to work even 1 time.
Am I just doing something wrong? Any advice?
Any help would be appreciated. I'm 2.5 hours into this calibration and tried it 2 times with no luck with the radius part in matter control. It just doesn't seem like it's making a difference.
Larry
Larry
