[resolved] thermistor got off
Posted: Wed Jan 07, 2015 3:37 pm
by jeffhuber
A print came loose off the bed and got all messy in my e3d hot end. I printed another print after just fine. Now the machine has cooled down but the thermistor says the hot end is hovering around 212c when it is obviously cold (around 33c). Thoughts on how to fix this?
Re: thermistor got off
Posted: Wed Jan 07, 2015 3:40 pm
jeffhuber wrote:A print came loose off the bed and got all messy in my e3d hot end. I printed another print after just fine. Now the machine has cooled down but the thermistor says the hot end is hovering around 212c when it is obviously cold (around 33c). Thoughts on how to fix this?
You most likely have a short somewhere, probably between the thermistor and the heater. First thing to do is to disconnect them from the Rambo board and measure the resistance of both. At room temperature the thermistor should be about 100KOhms and the Heater about 3Ohms.
Posted: Wed Jan 07, 2015 3:54 pm
by jdurand
And NO connection between them or to ground.
Re: [resolved] thermistor got off
Posted: Fri Jan 09, 2015 8:41 pm
by jeffhuber
half of the thermistor wire had completely sheared off. strange. anyways - i replaced it with a backup i had and all seems good to go
