Homing problem
Posted: Sat Jan 03, 2015 12:12 am
by TheCommonCathode
I'm having a problem I can't figure out for the life of me. When I hit the home button in Rep, or or the printer itself, the arms move up, bit only about 1 or 2 cm then stops. If any info is need I can provide it.
Re: Homing problem
Posted: Sat Jan 03, 2015 1:12 am
by lightninjay
Sounds like a case of "accidentally set your Z-height to something ridiculous".
Go into the "Advanced Settings" at the bottom of the list, then "Calibrate Z-Height".
Put the nozzle down as close to the bed as possible (paper's width) then set the height.
Home and all should be good. :)
Re: Homing problem
Posted: Sat Jan 03, 2015 10:44 am
by TheCommonCathode
It seems my last post didn't post. But it's still not homing and I'd rather not reinstall the firmware. It homed just fine for a few min yesterday, but not anymore. And I'm still at that point in the PDF.
Re: Homing problem
Posted: Sat Jan 03, 2015 12:25 pm
by Mac The Knife
If it was homing alright before, I would check the endstop switches, and their wiring.
Re: Homing problem
Posted: Sat Jan 03, 2015 12:36 pm
by TheCommonCathode
Endstops work fine. But I think it's the EEPROM. I think I may have typed in the values for the hot end autotune in the wrong boxes, so I'm entirely redoing that.
