Hot End smoking a tiny amount?
Posted: Tue Dec 30, 2014 4:05 am
Finally getting up to the Calibrate Hot End step in the manual, the instructions say "Your hot end may smoke a tiny, tiny amount when reaching temperature"
I started it, watched the thermistor start climbing to 150C, then my hot end started making very small spitting noises and giving off a bit of smoke, not more than a candle, but it kept smoking a small bit and spitting. Is this normal? I shut the power off before it could go any higher and am a little worried about starting it up again...
Basically it's a constant stream of very light smoke, like a candle that's been blown out, with intermittent spitting noises.
