Taller objects having warping issues
Posted: Mon Dec 29, 2014 7:34 am
by netdefilr
Not sure how to solve this. But the pictures could explain what is happening.
Re: Taller objects having warping issues
Posted: Mon Dec 29, 2014 9:33 am
by craftymethod
are those three seperate pieces?
Posted: Mon Dec 29, 2014 9:43 am
by BenTheRighteous
Is that ABS? Unless you need the strength, I recommend printing big decorative pieces out of PLA to save yourself the headache of warping.
Posted: Mon Dec 29, 2014 10:20 am
by JFettig
Abs likes to crack and warp unless temps can be held high. Build an enclosure that holds in the heat. What is your nozzle temp? I keep mine 235-240 which helps
Posted: Sat Jan 03, 2015 12:13 pm
by netdefilr
I used ABS. I'm trying to print with PLA now instead for larger pieces. I believe that was printed at 225.
