Super infrequent power overloads
Posted: Wed Dec 10, 2014 11:58 am
I built my kit about 2 weeks ago, and for the most part, it's awesome.
But lately, about 20% of the time that I manually heat the hot end and bed, a few minutes later the power will trip and the whole machine will shut off. Then I have to turn the the power switch off and back on for it to power back on. I know I’m not the first to have this problem. And this has only happened a few times during an actual print. Mostly it happens when I manually heat them together. Then sometimes the trip will be caused by manually running the extruder after the hot end and bed are already heated. So It’s obviously happening from an overload of power.
I have checked the wiring going into the power connector in the rambo, and all seems secure. And again, this is a semi-infrequent occurrence. I have run several 10 hour prints without problems. But it still happens every now and then. How can I trouble shoot the cause of this issue?
I have been told by a Max v2 owner who’s an electrical engineer to possibly bundle 1 addition matching PSU wire to each of the 4 single wires that are inserted into the rambo power connector. I am electronically challenged, and i wanted to see if this is something that others would recommend before I tried it.
Could someone tell me exactly what is being powered by each of the six connections on the rambo power connector ( the 2 bundles of 4 wires and the 4 singles)
Also what would be the best process for checking the voltage drop on the PSU and rambo power connector? (remember I'm electrically challenged) I just want to figure out how to diagnose these overloads. Much appreciated!!!
