Bump bump bump, then... layer shift
Posted: Sat Dec 06, 2014 4:20 pm
Well, it didn't take me long to find another puzzle for the forum. I've got plenty of data on this one, and one or two theories. I've tried searches, but (perhaps due to my inexperience), can't come up with a search term to find a thread that covers a similar problem. So, here it is ;
Since I fixed the last problem, I've been hearing a "bump, bump, bump" when the head lowers to begin a print. At first things were going fine apart from that - I probably should have investigated, but since the prints were coming out lovely, I just carried on.
Yesterday, I had two consecutive failures. In both cases, at about 2mm height there was a "bump" again, and the print head seemed to move back about 10mm. It carried on printing here, meaning the print was misaligned and failing, so I cancelled.
When I run the skates up and down the towers with my hands, all three of them seem to slip into a "notch" around about the places where (on their way to begin a print) I hear a "bump". The height of the three "bump spots", measured from the top of the melamine lid of the base unit, to the top edge of the melamine on each skate, are ;
210mm, 287mm, and about 362mm
As I say, when I run the skates up the towers, they kind of slip into what feels like a notch at these exact points - same height for each skate, at all three locations. When I watch the head descend to print, it appears to be making the "bump" noise as it passes each of these points. I don't want to run it again until I resolve this issue, but I'd guess that the layer shift takes place around the lowest "bump spot".
So, on to possible reasons. I tightened the belts up when I was fixing the last problem. Is it possible I made them too tight?
I also tightened all the screws I could access - I wonder if I've misaligned anything?
I tightened the skates - I think they're right, according to everything I've read - but does this seem a likely consequence of them being too tight? Or even still too loose?
I'm going to loosen the belts a bit, as I've a feeling it has to be that. Does anyone have any thoughts?
