Side panel w/ fan
Posted: Thu Oct 30, 2014 6:34 pm
by Austinh100
I designed a custom side panel with a hole for a 40mm fan and thought i would share.
Panel:
http://www.thingiverse.com/thing:523115
Fan:
http://www.amazon.com/gp/product/B0016CMCBG
Let me know if you have any questions
Re: Side panel w/ fan
Posted: Fri Oct 31, 2014 1:50 pm
by BONE
Looks nice, but why not just drills needed for the fan opening and mounting in the original piece?
Posted: Fri Oct 31, 2014 3:02 pm
by Nylocke
Why not a larger fan? More airflow seems like a good thing to me, I have 2 5V 70mm fans from an old laptop cooler on my X3 Pro that work pretty nice, need a better mount for them though..
Posted: Tue Nov 11, 2014 10:28 am
by techstorage
I went with a 92mm side fan. I had access to someone with a laser cnc that helped me do some customizing. The fan just fits in the normal side opening.
Posted: Tue Nov 11, 2014 1:14 pm
by Jimustanguitar
I like that acrylic piece a lot. I think I'll have to do that!
Posted: Tue Nov 11, 2014 11:55 pm
by crocky
techstorage wrote:I went with a 92mm side fan. I had access to someone with a laser cnc that helped me do some customizing. The fan just fits in the normal side opening.
Did you just feed it with 12volts?
I've got one of those and I plan on 2 covers with fan holes in them and only one fan, haven't tried to power it yet
Posted: Wed Nov 12, 2014 1:40 am
by Jimustanguitar
BONE wrote:Looks nice, but why not just drills needed for the fan opening and mounting in the original piece?
Because the plastic coating on melamine tends to chip and flake and looks crappy after you cut it.
[img]
http://i.imgur.com/Z9k8f0k.png[/img]
[img]
http://i.imgur.com/v1U4ik4.png[/img]
Posted: Wed Nov 12, 2014 7:21 am
by Mac The Knife
That's why you're supposed to finish it off with a fan guard you print.
Posted: Wed Nov 12, 2014 8:26 am
by Jimustanguitar
Working on that, yup
Posted: Wed Nov 12, 2014 10:17 am
by nitewatchman
Cut and drilled mine using an end mill (think router cutter), chipping is not too much of an issue.
Mounted 2 90mm 5VDC Fans.
Posted: Wed Nov 12, 2014 10:19 am
If you used a fish-tail bit, that would explain the lack of tearing.
Posted: Wed Nov 12, 2014 1:16 pm
geneb wrote:If you used a fish-tail bit, that would explain the lack of tearing.
Would a wt bit work without tearing the melamine?
Posted: Wed Nov 12, 2014 2:30 pm
by nitewatchman
Don't know what that is?
Used a 1/8" Carbide 2 Flute End Mill, 5140 RPMS, 45IPM, Climb Cutting and circular interpolated the screw holes slightly to open them up.
Posted: Wed Nov 12, 2014 3:24 pm
by Jimustanguitar
Fish tail bits usually are 2 fluted. It's the point that differentiates them.
[img]
http://img.auctiva.com/imgdata/7/0/5/7/ ... jpg?nc=273[/img]
Posted: Wed Nov 12, 2014 3:45 pm
by Bradley
I have not done this modification yet, have you noticed it running any different/better with the fans? Thanks!
Posted: Thu Nov 13, 2014 9:08 am
by techstorage
I picked up a PC power supply cable adaptor from radio shack and spliced the fan wire to the 12v plugs that were for hard drives ( yellow and black wires). When I have the printer on the fan is running.
Side note, for some reason not all of my power plugs had power on the when I did this but I did get one with voltage so I didn't have to splice the fans to the larger pugs like we did to the Rambo board.
Posted: Thu Nov 13, 2014 4:52 pm
by crocky
Thanks,
That was the power wires from the fan right?
Black and yellow to have 12 volts applied to them, I know there are other colours but we don't need them!
Posted: Thu Nov 13, 2014 9:30 pm
by techstorage
The blak and yellow are the power supply cables, fans will be labeled depending on manufacture. Mine was also yellow and black for 12v.
