What version Arduino will repetier files for ORION compile?
Posted: Wed Oct 08, 2014 1:06 am
I downloaded the stock Repetier firmware files...."Repetier-Firmware-master.zip"
that compiles successfully in Arduino 1.5.8
I downloaded the Orion firmware files ....."Repetier-091-ORION-master.zip" from githum here...
https://github.com/seemecnc/Repetier-091-ORION
That gives me compile errors in ui.cpp....using Arduino 1.0.6, and 1.5.8
The stock ORION files obviously should compile in some version of Arduino....but not for me!
Errors are shown below.
any and all help appreciated....
C:\Program Files (x86)\Arduino/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=158 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI C:\Users\BOBSHA~1\AppData\Local\Temp\build7855876795234742609.tmp\ui.cpp -o C:\Users\BOBSHA~1\AppData\Local\Temp\build7855876795234742609.tmp\ui.cpp.o
C:\Users\BOBSHA~1\AppData\Local\Temp\build7855876795234742609.tmp\ui.cpp: In member function 'bool<anonymous struct>::showEntry() const':
C:\Users\BOBSHA~1\AppData\Local\Temp\build7855876795234742609.tmp\ui.cpp:120:35: error: ISO C++ forbids declaration of 'type name' with no type [-fpermissive]
f = HAL::readFlashByte((const prog_char*)&filter);
C:\Users\BOBSHA~1\AppData\Local\Temp\build7855876795234742609.tmp\ui.cpp:120:29: error: expected primary-expression before 'const'
C:\Users\BOBSHA~1\AppData\Local\Temp\build7855876795234742609.tmp\ui.cpp:120:29: error: expected ')' before 'const'
C:\Users\BOBSHA~1\AppData\Local\Temp\build7855876795234742609.tmp\ui.cpp:123:36: error: ISO C++ forbids declaration of 'type name' with no type [-fpermissive]
f2 = HAL::readFlashByte((const prog_char*)&nofilter);
C:\Users\BOBSHA~1\AppData\Local\Temp\build7855876795234742609.tmp\ui.cpp:123:30: error: expected primary-expression before 'const'
C:\Users\BOBSHA~1\AppData\Local\Temp\build7855876795234742609.tmp\ui.cpp:123:30: error: expected ')' before 'const'
C:\Users\BOBSHA~1\AppData\Local\Temp\build7855876795234742609.tmp\ui.cpp: In member function 'void UIDisplay::adjustMenuPos()':
47: error: ISO C++ forbids declaration of 'type name' with no type [-fpermissive]
uint8_t mtype = HAL::readFlashByte((const prog_char*)&(men->menuType));
41: error: expected primary-expression before 'const'
41: error: expected ')' before 'const'
C:\Users\BOBSHA~1\AppData\Local\Temp\build7855876795234742609.tmp\ui.cpp: In member function 'void UIDisplay::nextPreviousAction(int8_t)':
49: error: ISO C++ forbids declaration of 'type name' with no type [-fpermissive]
uint8_t entType = HAL::readFlashByte((const prog_char*)&(ent->menuType));// 0 = Info, 1 = Headline, 2 = submenu ref, 3 = direct action command
43: error: expected primary-expression before 'const'
43: error: expected ')' before 'const'
Error compiling.
Error compiling.
