ABS stuck on PEI , any tips to remove?
Posted: Sun Oct 05, 2014 9:56 pm
by Holy1
Hi, I have made a part using ABS on the pei bed as I have done many times, however this time I can't get it to release. The part broke off leaving about 1/4 inch stub. Does anyone have any trick to getting this off without damaging the PEI? It's about 3 inch diameter.
Thanks
Re: ABS stuck on PEI , any tips to remove?
Posted: Sun Oct 05, 2014 9:58 pm
by Nylocke
Acetone. PEI is resistant to it, just put some on and it should melt the ABS away
Posted: Sun Oct 05, 2014 10:01 pm
by Holy1
Nylocke wrote:Acetone. PEI is resistant to it, just put some on and it should melt the ABS away
Of course. Thanks, I had a brain fart. I totally knew that.
Posted: Sun Oct 05, 2014 10:51 pm
by nitewatchman
You might also try refrigerating the build plate for an hour or so. I often have to attack mine with a 1" Butt Chisel and lever it up from the PEI.
nitewatchman
Posted: Mon Oct 06, 2014 3:43 am
by Generic Default
I'm having the opposite problem. What temperature were your bed and hotend during the print, which side of the PEI did you use, and did you wipe it with alcohol or hairspray before printing?
Posted: Mon Oct 06, 2014 7:38 am
by Holy1
Generic Default wrote:I'm having the opposite problem. What temperature were your bed and hotend during the print, which side of the PEI did you use, and did you wipe it with alcohol or hairspray before printing?
I was printing at 75, 228. I use the glossy side because I like the shine and did not use anything prior to the print. I will rarely use alcohol.
nitewatchman wrote:You might also try refrigerating the build plate for an hour or so. I often have to attack mine with a 1" Butt Chisel and lever it up from the PEI.
nitewatchman
Tried that but it wasn't tall enough to get a grip on.
Posted: Thu Oct 09, 2014 2:29 am
by Renha
I have used blade screwdriver, you could try chisel. Just place it at small angle at bottom of part, and strike with hammer it's head. ~3 bottom layers could be damaged
