cura printing with Max v2
Posted: Tue Aug 19, 2014 7:30 pm
by duvdev
Hello,
Is there any profile or presets for printer?
If I calibrate it as in the manual will it work as it supposed in cura?
Thanks.
Re: cura printing with Max v2
Posted: Wed Aug 20, 2014 7:42 am
by Jimustanguitar
Posted: Tue Aug 26, 2014 12:20 am
by singh336
those are for slic3r, but i guess you can take the info from them and plug them into cura
Posted: Tue Aug 26, 2014 12:38 am
by DavidF
with cura, just run the first wizzard and set up the printer dimensions and tell it that its a rostock. take the cura G code and open it int repiter and then run or save it to sd card. The printer settings themselves are stored on the eprom. Hope this makes sense, Ive kicked back a few pints LoL
Posted: Mon Sep 15, 2014 8:45 pm
by Nylocke
What I generally do is set the print speed to 50mm/sec (I print a tad bit faster) and the travel to 200, retract to 2-3 at 50mm/sec, and first layer speed I bump to 30. Also I change the advance settings (drop down menu) so there is 1mm of "z hop" (where it lifts the effector after a retract) and I change the min skirt loops to 3. Generally pretty good prints.
