MatterSlicer inverted layers
Posted: Fri Aug 15, 2014 5:50 am
by teoman
I am just beginning with matterslicer and on a print i noticed that it prints a couple of layers in inverse. I.e. while printing a hollow tower type of object the walls do not get printed but the hollow inside has a "floor" in it.
Not sure if it is the model or the slicer. I am able to see the layer inverted in the View mode of MatterControl.
The STL was designed by my brother. So there could be an error in that. BUT when i first load it, before GCODE generation, it appears fine.
Photos should be able to explain it better.
Re: MatterSlicer inverted layers
Posted: Sat Aug 16, 2014 1:19 pm
by teoman
Seems it was like the stl model.
Posted: Sat Aug 16, 2014 6:05 pm
by critical_limit
switchted off the automatic failure correction?
Had some trouble before with failure correction switched on. After I switched it completly off, everything was fine.
Same with Cura on some stl files I had. After switching all off, it was ok and well printed.
Maybe try and report...
