Question regarding building without buying additional stuff
Posted: Tue Jul 22, 2014 8:28 am
Hi, im at the last stage of the build of my Rostock MAX V2.
Clearly i must have misunderstood something when i bough the kit.
I thought i bought a complete kit for building but there is so much extra stuff required to get this kit together.
When youre located in another country than USA, its definitely not so easy to source down alot of the extra stuff...
Question regarding the Hot-end assembly. Its pictured in the build manual with barrel crimp connectors on the resistor pin, but there is none in the kit.
Can i solder up the wires direcly to the resistor leads, or will this get hot enough to actually desolder the wires ?
Can i finish up the rest of my build without the jameco crimping tools mentioned in the start of the manual or is it required to get all the connections done on the PCB later? The crimping tools is not availiable in Norway..
