Bed Collision With Particular Object
Posted: Sat Jul 12, 2014 5:00 pm
Hey. I've been trying to print a larger filament spool for my Rostock. I'm using an STL someone posted here. Every time I try to print it, a few minutes into the first layer the steppers start skipping as the hot end tries to drive down into the bed. It seems to happen in the same place every time, around line 250. I've tried slicing it with both Slic3r 0.9.9 and 1.1.5 with the same result. I'm using pretty standard settings. When I look at the Gcode preview in Repetier I can't see any point when the travel goes below the plane. Anyone got any ideas? I've attached links to the STL and the Gcode.
Rostock Spool holder - Nylon.STL
RSPOOL.GCO
RSPOOL.GCO
