Hot End and Bed Shut Off Mid Print
Posted: Thu Jun 26, 2014 11:43 am
by grasshorse
Hello,
I'm curious if anyone else has had a problem where the Rostock Max starts a print, gets a few layers down, and then shuts off the power to the heated bed and the hot end. It's not a fuse because I can reset the printer and then bring everything back up to temperature. The head is not clogged, because I can extrude filament no problem. If anyone has any ideas I would love to hear them.
All the best,
Steve
Re: Hot End and Bed Shut Off Mid Print
Posted: Thu Jun 26, 2014 2:25 pm
grasshorse wrote:Hello,
All the best,
Steve
Does the whole thing reset when it happens, i.e. do you lose the connection in the host software?
My guess would be a bad PSU, or the movement causing a temporary short, either of which will cause the PSU to temporarily shut down
Posted: Wed Jul 02, 2014 11:21 am
by grasshorse
Nope, the entire machine keeps working. So the power supply can't be the problem. It seems that only the heating elements shut off. It isn't fuses either, because it came back up to temperature after resetting the machine.
Steve
Posted: Wed Jul 02, 2014 12:16 pm
by enggmaug
Did it happen just once, or is it a recurrent problem ?
If it does happen, does it happen with one STL file, or all, or some ?
Maybe you could have a bad connection in a thermistor.
What temperature does the printer display when you are in that situation ? Does it display the target temp, the cooled down temp, or "def" ?
Posted: Sat Jul 05, 2014 10:45 am
by grasshorse
Hello,
It's happened a few times now. I tried a different part and the same thing happened again, and I have made a rather fiddly YouTube video to show the result. The bed is entirely cold and I imagine that the hot end is as well. I didn't remember to check the temperature read-out. Something that is interesting is that it took about twice the time and material for this print to fail as it did the print before. Any more ideas?
Thanks for the help!
Steve
[youtube]http://youtu.be/mhfIbl7aicE[/youtube]
Posted: Sat Jul 05, 2014 12:25 pm
If the LCD reads DEF for the temperature at the point of the failure, then it's gone into failsafe because it measured a temperature out of the expected range. This is usually a result of a loose wire on the Hotend thermistor, at some point the motion causes a disconnect for just long enough that it reads the open circuit.
But it could be a lose wire on the bed thermistor, or an intermittent short on either.
Posted: Sat Jul 05, 2014 8:34 pm
by grasshorse
I did receive that error! I will check into that. Likely, just re-wire the thermistor. Thanks for your insight!
All the best,
Steve
