Layer fan mod.
Posted: Fri Jun 13, 2014 2:31 pm
by Boundless
Hey Guys,
I have made a small change to the layer fan using Sketchup. I simply closed it off on the bottom except for the end. This creates more of a wind tunnel that forces air right at the area being printed, instead of it spreading over most of the bed. The air flow is really impressive. I like it so much, I am adding 2 more of these to the effector.
What do ya think?
[img]http://s9.postimg.org/w3gqhs8tb/image.jpg[/img]
Re: Layer fan mod.
Posted: Fri Jun 13, 2014 2:54 pm
I think that it is a great idea. Are you willing to share the stl file?
Re: Layer fan mod.
Posted: Fri Jun 13, 2014 3:31 pm
by Boundless
Of course, here ya go.
Boundless-Blower-Fan-Mod.stl
(668.69 KiB) Downloaded 433 times
Re: Layer fan mod.
Posted: Fri Jun 13, 2014 7:57 pm
by Holy1
Nice Mod!
Re: Layer fan mod.
Posted: Fri Jun 13, 2014 9:27 pm
Thanks for sharing that. I like the fan housing better because most of the air comes out at the nozzle.
Re: Layer fan mod.
Posted: Tue Jun 17, 2014 10:56 am
by guanu
here's the new design we are using here at the shop... since we redesigned the platform and its thicker, I changed the fan shroud so it doesn't hit the platform when installing, also capped the bottom, and capped off the tab area so the fan can shift less...
Guanu
Re: Layer fan mod.
Posted: Tue Jun 17, 2014 11:05 am
by Boundless
Sooooooo, its a fan shroud design-off ehh? Throwing down the gauntlet?
Kidding, that looks great! I knew my design would be made obsolete in a few days lol. Thanks for the STL. I'll give it a try.
Re: Layer fan mod.
Posted: Tue Jun 17, 2014 11:16 am
by Jimustanguitar
Where are you guys sourcing the fans? They're a bit salty, so I haven't picked any up yet.
Re: Layer fan mod.
Posted: Tue Jun 17, 2014 11:25 am
by guanu
I go to the stock area and grab em lol... http://seemecnc.com/collections/parts-a ... blower-fan these are what I designed the shroud for..
dont feel bad boundless, I'm the one who originally designed the shroud, and decided to throw in the capping idea into the new revision... originally I didnt because of back pressure.. and there is still a decent amount of it, but the airflow out the tip is quite a lot even with this design, I just had to add a cutout because the new thicker platform needed clearance.. and while I was at it, decided to cap off the tab area.
Guanu
Re: Layer fan mod.
Posted: Tue Jun 17, 2014 11:53 am
by Boundless
I like what you did there. The capped off area will keep the fan pointed at the nozzle instead of being free to spin on the screw. I also liked the rounded end. This should give a bit more clearance from the surface as well.
Thanks again Guanu.
Re: Layer fan mod.
Posted: Tue Jun 17, 2014 12:36 pm
Thanks for the new fan Guanu.
Re: Layer fan mod.
Posted: Tue Jun 17, 2014 3:39 pm
by bvandiepenbos
Nice revision. Thanks Guanu.
I am curious, what are the square bumps on each side for?
Re: Layer fan mod.
Posted: Tue Jun 17, 2014 5:46 pm
by Boundless
Strength, support.
Re: Layer fan mod.
Posted: Tue Jun 17, 2014 6:18 pm
by nitewatchman
bvandiepenbos wrote:Nice revision. Thanks Guanu.
Keeps the shafts on the Effector from walking out in that direction on mine at least.
nitewatchman
Re: Layer fan mod.
Posted: Wed Jun 18, 2014 10:32 pm
by Mike B
I was having issues with the original layer fan shroud impacting my prints. I was glad to find the modified design. Thanks!
Re: Layer fan mod.
Posted: Wed Jun 18, 2014 11:24 pm
by Tinyhead
Now you guys just need to redesign the fan to fit for the V1 owners. ;)
