hagemeyer's build Rostock Max v2
Posted: Fri Jun 06, 2014 12:48 pm
by hagemeyp
started a few weeks ago, slowly making progress. tonight I'll be adding the extruder and finishing up the top.
Re: hagemeyer's build Rostock Max v2
Posted: Fri Jun 13, 2014 9:42 pm
by JohnStack
Done yet?
Posted: Wed Jun 18, 2014 9:33 am
by hagemeyp
Finished and printing! https://vimeo.com/user29107994/videos
I just wish I could figure out how to print from the SD card
Posted: Thu Jun 19, 2014 4:57 pm
by JohnStack
You will - 8.3 file name format... if you have old rom... otherwise, shitty reader?
I iike the big old landing pad you have on there. I never got that extreme but it is a very good idea.
Posted: Fri Jun 20, 2014 8:35 am
by hagemeyp
So I tried disconnecting the USB completely. RAMBO is powered from 110v, not USB.
-I preheat for ABS. I can read files from the SD card.
-I can execute GCODE from the SD card, like scripts to home to towers and other delta ballet style pieces.
-Everything is hot and at the expected temps, so I select a file to print "simple.g".
-Extruder drops to the bed, prints the brim, proceeds a bit more, then stops. Nothing more.[/list][/list]
one more thing, all files were sliced with Cura. However I can successfully load them into Repetier-Host and print the GCODE through that interface over USB.
Suggestions?????
Posted: Fri Jun 20, 2014 9:38 am
hagemeyp wrote:So I tried disconnecting the USB completely. RAMBO is powered from 110v, not USB.
Suggestions?????
If you are using the SD card that was sent with the LCD, it is notorious for not working correctly with the symptoms being what you have described.
You need to purchase a class 10 SD card (not Kingston) then your problems should be over.
Posted: Fri Jun 20, 2014 9:40 am
by hagemeyp
thanks- I will do so
Posted: Sun Jun 22, 2014 7:28 pm
by hagemeyp
Bought this one, same problem. I preheat for abs. Then one it's heated, I insert card and select a small file. Print starts, but stops before the brim is even finished. Slicing is done with cura.
More suggestions?
Posted: Sun Jun 22, 2014 10:08 pm
Sometimes the cables from the card reader is picking up EMI noise, the fix is to place ferrite cores on the cables.
See this link: http://forum.seemecnc.com/viewtopic.php?f=54&t=2530
Posted: Mon Jun 23, 2014 11:06 am
by hagemeyp
ugh- ribbon ferrite cores ordered. Tonight I'll pull the LCD/card reader out and tidy up the stepper wires.
Posted: Mon Jun 23, 2014 9:54 pm
by hagemeyp
Pulled off the front cover, stretched out the ribbons. Printed directly from the sd card without issues. Guess it needs the ferrite cores!
Posted: Tue Jun 24, 2014 7:59 am
by barry99705
hagemeyp wrote:Pulled off the front cover, stretched out the ribbons. Printed directly from the sd card without issues. Guess it needs the ferrite cores!
You can also try wrapping the ribbon with aluminum foil. Kapton over any solder points so you don't short anything, and then ground only one end.
Posted: Tue Jun 24, 2014 3:58 pm
by AndThenSome09
You can salvage ribbon ferrite sleeve things out of those scanner copier printers, I got a few out of two I just salvaged the other day.
Posted: Tue Jun 24, 2014 4:31 pm
You can buy them at http://www.digikey.com/product-detail/e ... ND/2465452
They are hinged and just snap on the cables.
You would need two of them. (one for each cable)
