Errors at end of print
Posted: Sun May 25, 2014 6:08 pm
by forrie
Hello - I've been playing around with Kiss and have getting some good results but have this annoying bug in Repetier-Host.
At the end of the print the nozzle freezes at the finishing point and I get error codes similar to the below lines, over and over again. The arm's won't reset to a home position, nor will the heaters turn off. Can anybody share their postfix GCode perhaps? or do you think it could be something else?
Error: expected line 31777 got 31789
Resend: 31777
I've looked at that line in the code, but it doesn't make sense as it's only 1/4 of the way through the file (print actually finishes).
I'm currently using:
G1 X70 Y0 F5000
G28
Slicer and Cura behave themselves at the end of the print....just can't figure this one out...
Re: Errors at end of print
Posted: Sun May 25, 2014 10:07 pm
by McSlappy
I had the same issue, turned out I was missing a ";" in the post gcode in kisslicer. Check those bits of code and paste what you have.
Posted: Sun May 25, 2014 11:00 pm
by forrie
You are correct! I had a line without a ;
All working now...Thanks!
Posted: Mon May 26, 2014 6:38 am
Does anyone have an idea what causes the line to be missing the ;?
A bug in the software?
Posted: Mon May 26, 2014 12:38 pm
It's probably a typo in the default config.
Repetier is a lot pickier about GCode formatting than some of the other firmwares, so it might not cause an issue on what ever Jonathan is testing on these days.
Posted: Mon May 26, 2014 1:23 pm
Polygonhell wrote:It's probably a typo in the default config.
Good point, thanks.
Posted: Mon May 26, 2014 5:48 pm
by forrie
I think I had a blank line at the bottom of the prefix screen...
