how to increase the max hot end temp
Posted: Tue May 13, 2014 1:05 pm
by mrbdrm
Hi
i have installed E3D and i don't know where to start to increase the temp limit on the hot end. searched for a guide with no luck.
can i change it from EEPROM configuration in repetier host?
Re: how to increase the max hot end temp
Posted: Tue May 13, 2014 1:23 pm
mrbdrm wrote:Hi
There is a max temp setting in the configuration.h of your firmware which you would need to increase then upload the firmware to the
Rambo board using Arduino.
Posted: Tue May 13, 2014 1:40 pm
by mrbdrm
ok
is there something i need to do before that? backup? or simply modify the maxtemp value then upload?
Posted: Tue May 13, 2014 4:15 pm
mrbdrm wrote:ok
You should just modify the setting in configuration.h then upload. Make sure that the maxtemp value you are changing
is for the extruder.
Posted: Tue May 13, 2014 4:42 pm
by mrbdrm
Eaglezsoar wrote:mrbdrm wrote:ok
thank you
i have done it and everything is good
what layer fan mount you guys recommend with this mount
http://www.thingiverse.com/thing:137140 from 626Pilot
the stock one is lower than the nozzle now.
Posted: Tue May 13, 2014 6:26 pm
mrbdrm wrote:Eaglezsoar wrote:mrbdrm wrote:ok
thank you
That is one of the problems with going to the E3D and I don't know if anyone ever created a layer fan that works without
sticking out so far it could risk banging on the uprights. If anyone knows what works best as a layer fan after installing
an E3D please step in and let us know.
Posted: Wed May 14, 2014 4:22 am
by mrbdrm
Posted: Wed May 14, 2014 8:51 am
That one looks great! I don't know how I missed that one but I'm glad you did not.
Thanks for finding it and sharing with us! I am printing one out as soon as I can.
GREAT FIND!
