Printing with FRP and Polycarbonate
Posted: Thu Apr 24, 2014 4:57 pm
I just received a request from MakeXYZ (I love those guys) for a short production run of 125pcs. The parts are for ATM machines, and are originally molded in FRP and polycarbonate. I wish to print replacement parts (the molded parts are no longer available) and make $$$. One part is FRP, about 2x2x10cm, shelled with 3mm walls and many small features. The other is about 2x2x1cm, PC and is fairly simple. Both parts will require support material. $20 per set plus a few hundred dollars for laser scanning/reverse engineering is a pretty nice payday for a (ahem) hobby printer. I figure it will take 3 weeks to a month working two to four hours a day.
The parts have to withstand heat, medium loading and long term abrasion, which is why they are originally made with the aforementioned materials. I saw a Kickstarter for carbon fiber filament, but haven't seen any in the wild. PC filament is available from Ultimachine and others
My plan is to use the project deposit to purchase two E3D hot end kits, so I can print support material, and achieve higher temperatures.
The hard part is finding fiber reinforced filament. I think I could probably print it in regular nylon and achieve the desired properties. Anybody know of any other sources for fiber filled filament? I could purchase a filastruder and fuss around with making my own (maybe?), but that sounds like a project-within-a-project, and I'm not sure how it'll work out. I need to research this option.
The other option is injection molds, but the $4-5K investment doesn't make sense for such a small quantity. I also thought about silicone molding, old-school style but I'm concerned about tolerances and available casting resins.
The project seems worthwhile and totally doable if I can find the right materials. I'm looking for opinions and guidance from the group. I'll continue researching and post my findings below.
Thanks,
Chris
Atlanta, GA
Thanks,
Chris
Atlanta, GA
