Printer stops half way into print same place every time
Posted: Sat Apr 19, 2014 12:27 pm
It's a 7 hour print that stops about halfway every time. 4 trys, change the layer thickness from .4 to .2 then to .21 . Tried 2 different versions of Slic3r. same results
Tried print from SD card and pc. SD card is a class 10.
generated by Slic3r 1.0.0 on 2014-04-18 at 12:37:17
; layer_height = .21
; perimeters = 3
; top_solid_layers = 3
; bottom_solid_layers = 3
; fill_density = .15
; perimeter_speed = 30
; infill_speed = 30
; travel_speed = 200
; nozzle_diameter = 0.5
; filament_diameter = 1.71
; extrusion_multiplier = 1
; perimeters extrusion width = 0.50mm
; infill extrusion width = 0.98mm
; solid infill extrusion width = 0.85mm
; top infill extrusion width = 0.85mm
G21 ; set units to millimeters
M107
G28
M104 S185
M190 S55
M109 S185
; BEGINNING OF HEAD MOVEMENT WARNING TONES
M120 S4 P10
G4 P40
M120 S4 P10
G4 P40
M120 S4 P10
G4 P40
M120 S4 P10
G4 P40
M120 S4 P10
G4 P40
M117 KEEP HANDS AWAY
G4 S3
; END OF HEAD WARNING TONES
G90 ; use absolute coordinates
G92 E0
M82 ; use absolute distances for extrusion
G1 F6000.000 E-5.40000
; perimeters = 3
; infill_speed = 30
M107
G28
M104 S185
M190 S55
M109 S185
M120 S4 P10
G4 P40
M120 S4 P10
G4 P40
M120 S4 P10
G4 P40
M120 S4 P10
G4 P40
M120 S4 P10
G4 P40
G4 S3
G92 E0
