Idea: Flexible Drive Line to Extruder
Posted: Sat Apr 05, 2014 12:18 pm
Getting rid of the bowden tube completely and coming up with an elegant solution for getting filament directly to the head is a good thing.
I don't know if anyone thought of this one but the primary challenge with putting an extruder with motor is too much mass.
I brought this idea up to Brian Van Diepenbos at MRRF....I was going to go ahead and develop it and probably protect the idea from the big boys but here it is:
What if on one end, the motor to the extruder was hooked up to a flexible drive shaft and on the other end of the shaft, an extruder?
Would this eliminate the bowden tube? What about lash? Increase it or no? Perhaps a really small extruder?
Perhaps carbon fiber components might also reduce weight (shaft casing) - of course, maybe the shaft doesn't need casing!
This could also work for Cartesians!
Any thoughts here?
Any thoughts here?
