pausing and resuming a print? (or running unattended)
Posted: Sat Mar 29, 2014 9:25 pm
Is it possible to manually pause, turn off the heat on the hotend (and bed?), then manually resume a print?
I ask because I've read of people having the Thermistor go out on them and the hotend go into a runaway heatup. I'm also reading that print times can get pretty nuts, with 8+ hours not uncommon. I don't have the printer yet, but for now I'd need to run it inside the house. With longer print times, I would have a hard time being able to stay home and awake to see a longer print through to the end. For longer print to run uninterrupted, I would have to leave it unattended for parts of the run, or overnight. I'd hate to think what would happen in the case of a thermistor failure if I wasn't around, or asleep in another room. And it seems those failures or near failures of this type are not unheard of. What is the actual fire hazzard if a thermistor fails in the middle of a long run and the print tried to keep going?
How do you guys deal with long print times?
Thoughts?
Thanks
-David
Thoughts?
Thanks
-David
