how to change layer extrusion width
Posted: Tue Mar 25, 2014 3:46 am
hello,
for some time now, my rostock max has been printing fairly well.
i have noticed since the first print it made how the bottom layer is more accurate and how it has thinner lines than the top layer and i could not figure out where to change these values.
now i found this: in this g-code it shows that it makes the bottom layer 0.4mm wide and the top layer, like the solid infill layer, 0.85.
i would like to have both top and bottom 0.4mm layers or something close, not to have the top layer twice as wide as the bottom, that looks awefull.
i'm using regular repetier host.
thanks in advance.
thanks in advance.
