Hello from Alexandria, VA
Posted: Tue Mar 18, 2014 1:48 pm
by WZ9V
After much lurking, I decided to uncloak.
I'm building a Kossel Mini with several modifications such as wheels instead of rails, E3D hot-end and heated bed. As a beginner, should have bought a kit but where is the fun in that? I have most of the mechanicals done and am moving into wiring the electronics. Planning to use a RAMPS 1.4 as my controller, still thinking about the software.
Re: Hello from Alexandria, VA
Posted: Tue Mar 18, 2014 1:58 pm
WZ9V wrote:After much lurking, I decided to uncloak.
If you plan on using the auto calibration probe you are pretty much limited to Marlin. Repetier has the function but Rambo actually works for the Mini Kossels.
