Casco Bay Designs MAX 2 build
Posted: Fri Mar 14, 2014 10:27 pm
by Kevinvandeusen
Got the crazy idea to paint it red, to get rid of the smell mostly. It looked pretty bad, until I stripped off the paper! I like it! Took 2 half hour sessions to paint, and I strip the paper as I go, for less monotony! Did this much assembly tonite in 2 hours. Including stripping paper!
Re: Casco Bay Designs MAX 2 build
Posted: Fri Mar 14, 2014 11:22 pm
by AndThenSome09
Looking good! Make sure to keep lots of pictures coming! We love pictures and am curious to see the build of a V 2 Max! :D
Posted: Sat Mar 15, 2014 1:38 pm
The red looks nice on there, good choice!
Posted: Sun Mar 16, 2014 11:46 pm
by Kevinvandeusen
Sunday afternoon work! Closer to printing! Got my delta arm slides a little reversed, and had to redo, but all in all, easy peasey! Maybe a notice in the manual about how the front and rear have offset screw holes so you cannot mess up!
Posted: Mon Mar 17, 2014 8:02 pm
by Kevinvandeusen
I am loving building my max2! I put the top section base plate on upside down! The extruder and filament mounts are backwards. Will this work, or do I need to flip it over?
Posted: Mon Mar 17, 2014 9:52 pm
by AndThenSome09
Personally, I would flip it over so everything is oriented the correct way.
Posted: Mon Mar 17, 2014 10:44 pm
by Kevinvandeusen
Yup, I will get off my lazy and flip it!
Posted: Sun Mar 23, 2014 5:05 pm
by Kevinvandeusen
the beast has had firmware installed, and whern I do a m119, I get l instead of h, any ideas? this looks to me as it thinks switches are pressed?
Posted: Sun Mar 23, 2014 5:11 pm
by Kevinvandeusen
well, I moved them to the ports next to where the manual said to connect, and it works! they are now plugged in the set closer to the motor wires, not closer to usb as shown on manual...
