Heated Bed Layering
Posted: Wed Mar 12, 2014 4:06 pm
by joecnc2006
I have the ONYX Round PCB Heated Bed original without the tabs.
Was wondering if I use 1/4" aluminum plate between it and the Rostock MAX Glass Build Plate 300mm If this would help distribute the heating surface, would like some input and thoughts.
I have 1/8" and 1/4" 6061 plate Aluminum on hand and can cut it to fit with a notch around the connections/led etc. but I think 1/8" is to thin.
Re: Heated Bed Layering
Posted: Wed Mar 12, 2014 5:29 pm
joecnc2006 wrote:I have the ONYX Round PCB Heated Bed original without the tabs.
Many users have used aluminum between the Heated Bed and the glass, the main criteria being that the aluminum must be absolutely flat, most users use
the cast aluminum MIC-6. If your 1/4" plate is flat it should be fine and will help to distribute the heat. Some users use the Onyx as a template and create
drilled and countersunk for the #4 screws, others just lay the plate on the Onyx. When I did mine I did drill the holes in the aluminum that matched the
Onyx and just used longer #4 screws.
Posted: Wed Mar 12, 2014 5:43 pm
by bvandiepenbos
The 1/8" will help distribute the heat well, and not take so long to heat up.
I have made and used 1/16" aluminum plate and it evens out the heat well also, plus I think it is thin enough that sandwiched between the glass and heated bed will keep it flat.
